I am putting a 74 engine with an internal thermostat in my 75 spider that has a larger radiator, so now the 74 lower radiator hose is not long enough. Has anyone found a hose or solution that will reach from the water pump to the lower end of the radiator?
Thanks.
Lower Radiator Hose
Gates number 21897
Gates number 21897. You will have to cut the hose near the label end, that's the part you don't use. The remaining hose is almost identical to the standard Fiat lower hose for the 1592 only a bit longer. There is enough curve in this hose to go around the alternator if mounted on the right side or an ac unit. The hose should curve out away from the water pump when fitted properly
Ralph
Hose on a 2000 Spider
Ralph
Pulleys are from millers mule.
See http://www.millersmule.com/
Nice guy
Here are more photos of the pulleys. Alternator was moved to passenger side.
http://mywebpages.comcast.net/ralphone/ ... ulleys.htm
Nice guy
