Spark plug selection
TulsaSpider
Your car is a: 1978 Spyder 124 2L
Post by TulsaSpider »
There seems to be many wide and various choices in the plug selection. My car is a 78 1800. Dual points, carb, seems to be all stock. The plugs that are in it seem to be in OK shape. I just want to make sure I get good plugs, temp range etc, for this setup. My plug wires should be coming in tomorrow.
Again thanks for the input!!
Clark
Re: Spark plug selection
I just use the Bosch Super or NGK, BPR6ES non platinum
perthling
Your car is a: 1974 124 Spider
Post by perthling »
I use the NGK BP6ES but have also used the BP5ES. BP6ES is the correct heat range however.
_______________________
Perthling
1974 Fiat 124 Spider (blade bumper 1756cc)
1974 Fiat 124 CC (same family since new)
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
1997 Coupe Fiat 20VT (daily driver)
http://www.fiatlancia.org.au
mdrburchette
Post by mdrburchette »
I'm running the NGK BP6ES and BP5ES. The lower the number the hotter the plug.
TulsaSpider
Sounds unanimous!
Thanks!!
