Hello,
Roof Frame Noise - Does anyone know of a tried and true process, procedure, or voodoo to isolate and rectify folded Spider roof frame squeaks and rattles? Grease it all up or split Delrin washers, or both?
Mark
Folded Roof Rattles
- opus10583
- Your car is a: 1978 CS1
Folded Roof Rattles
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
- bradartigue
Re: Folded Roof Rattles
There are very few adjustment points, make sure they're good and tight. I'd use dry graphite on the joints. Delrin would turn your rattles into squeaks and I'm not sure how you'd use it in the first place.
1970 124 Spider
http://www.artigue.com/fiat
- opus10583
Hi Brad,
Thanks! Thinking out loud a little...
I'll try the graphite.
Thanks again,
Mark
Thanks again,
Mark
bradartigue wrote:There are very few adjustment points, make sure they're good and tight. I'd use dry graphite on the joints. Delrin would turn your rattles into squeaks and I'm not sure how you'd use it in the first place.
- toplessexpat
I had a rattle I couldn't track down on the 2000.... And finally worked out it was the top latch. Over the years the spring had weakened and when the top was down (and no boot cover on it), the latch would bounce around slightly making an annoying rattle. A quick pinch tightening it up worked fine.
- opus10583
Hi,
Yes, I've got that.
Mark
Yes, I've got that.
Mark
toplessexpat wrote:I had a rattle I couldn't track down on the 2000.... And finally worked out it was the top latch. Over the years the spring had weakened and when the top was down (and no boot cover on it), the latch would bounce around slightly making an annoying rattle. A quick pinch tightening it up worked fine.
My top never rattled until I got hearing àids. I put on the hold down straps and the rattle is gone. On long drives I wear ear plugs.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
- toplessexpat
I "hear" you... oh, maybe I don't.....
Andy
(ReSound Aleras)
Andy
(ReSound Aleras)
