SuperPro Urethane bushings
I now have SuperPro urethane bushings in stock for the Spider. The kits are packaged individually for each location;
front upper arms
front lower arms
sway bar ends
rear upper trailing arms
rear lower trailing arms
panhard rod
The control arm bushings are the Comfort line, which is designed for street use so that the ride is not so harsh. They're available now in our ebay store and will be on our website shortly. Of course you can always order by phone
81SPIDERMATT
Re: SuperPro Urethane bushings
Post by 81SPIDERMATT »
thought I had read that on my 81 trailing arm bushings are not rebuildable .... is that not true ???
the rear bars that have the "hourglass" shaped ends are rebuildable
btoran
Your car is a: 1975 Fiat 124 Sport Spider
Post by btoran »
what advantages do these have over standard bushings?
1975 Fiat 124 Spider
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
btoran wrote:what advantages do these have over standard bushings?
I'm sure they will last longer. I can't count the number of times I've replaced my bushings in 255000 miles.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Ramzi
Post by Ramzi »
81SPIDERMATT wrote:thought I had read that on my 81 trailing arm bushings are not rebuildable .... is that not true ???
The late arms are re-buildable but its much more difficult. Most ppl say you must 'burn' the old cylindrical bushings out and press in the new ones. We sell the bushings, but are currently out. Hope to have more the 1st part of next year.
Ramzi
the advantage is less deflection and much longer life
burgandy81
Your car is a: 1981 FIAT Spider 2000
Post by burgandy81 »
Hi Mark,
Great product!
Could you please comment on the 'comfort' description of these bushings?
Harder, softer or similar to current rubber replacements?
Best regards,
Jordan
SuperPro makes two levels; Competition or Comfort. The Comfort line is for street use and is does not result in a harsh ride. We've been using the Comfort bushings on cars for a couple of years and they really produce a confident feeling in the suspension. SuperPro recently set up a west coast distributor, so we're finally able to get these in sufficient quantity to offer them.
njoconnor
Your car is a: 1972 124 Spider
Post by njoconnor »
Mark: for the front control arm kits: 1 kit per side?
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
one kit does both sides
