bought this car this way.
car runs but wont go into gear while running... goes in to all gears if car in not running.
If i try to start in gear with clutch depressed then it learches forward
anyone lives around crown point indiana and can help ?
how do i check what is the problem. i'm not an expert.
looks like cable is good. spring exists.
please HELP.
regards
raviv
clutch problem in 1983 spider - wont shift
- Your car is a: spider 1979 cs2
Re: clutch problem in 1983 spider - wont shift
Sound to me that your clutch isn't working.
Depress the clutch pedal and have someone look under the car, does the clutch lever move back and forth? If it doesn't then either the cable is broken, disconnected at the pedal or clutch lever, or your pedal assembly is messed up.
if it's been sitting the disc may be rusted to the flywheel
I had a Massy Ferguson tractor last year the customer had sunk, pulled out of mud, then let sit all winter. I tried everything to break that disc free. Finally had to split the tractor to do it. And really, once apart, one good tap broke disc away from flywheel.
Oh I digress. Mark may be right. Tough to unstick em. Not sure if you can get to see disc, if you can, depress clutch, smack disc with anything you can reach it with. Good luck
There is a cover on the lower front of the bell housing that can be removed. Perhaps a whack or 10 on the flywheel there might help.
What I do is the following when my clutch is stuck:
1- Jack up rear end (via differential)
2- Put car in first gear
3- Start engine
4- Depress clutch
5- Press brake pedal
It's worked every time I tried it (about 3 times).
3- Start engine
4- Depress clutch
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
This is better than my method. I usually just put the car in first gear and make sure the battery is good n' hot. pres the clutch in and bump the starter a few times.bobplyler wrote:What I do is the following when my clutch is stuck:
3- Start engine
4- Depress clutch
So Raviv,
Did you ever find out what was wrong? If so, what fixed it? I have a similar problem.
72 124 spi bought new - the carcass is buried in the backyard
71 spi swapped drivetrain from 72 - sold in 88
71 coupe - traded for new Lancia
77 Lancia Beta Saloon
71 1608 spider - impulse buy - project
