2L Intake Removal
Kent124
2L Intake Removal
Post by Kent124 »
After getting all seven bolts / nuts off is there a trick to getting the intake manifold off? Front end seems to be hitting a plate behind the timing belt. Do I need to bend the plate a bit to get it out or is there a magic technique?
124JOE
Re: 2L Intake Removal
Post by 124JOE »
you can remove the back cover or bend it out of the way
Kent124
Post by Kent124 »
I may have found the issue. I believe the black shield behind the timing belt has a 90 degree bend in it and one of the bolts went through it. (The shield on the passenger side has a similar bent that a bolt goes through.)
Hopefully if I can bend the tab back it will free up the manifold. Fingers crossed :)
most owners do away with those rear covers
Kent124
Post by Kent124 »
Looks like the driver's side cover is secured by the timing belt tensioning spring mechanism.
Kent124
Post by Kent124 »
Looks like simply bending the tab didn't work.
Has anybody removed the driver's side rear timing belt cover?
124JOE
Post by 124JOE »
have a look
some guys remove them all
theres many different styles
back in the day a mecanic wouldnt even put it back on if having to remove it
Wheel
Your car is a: 1982 Fiat Spider
Post by Wheel »
These are the best pictures I could dig up. Hope it helps.
1982 Fiat Spider
Kent124
Post by Kent124 »
Thanks that last picture really helped.
fiat218
Post by fiat218 »
it slides off, i had the same problem and it finally came off, it like a hook open slot i belive
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
