2L Intake Removal
2L Intake Removal
After getting all seven bolts / nuts off is there a trick to getting the intake manifold off? Front end seems to be hitting a plate behind the timing belt. Do I need to bend the plate a bit to get it out or is there a magic technique?
- 124JOE
Re: 2L Intake Removal
you can remove the back cover or bend it out of the way
I may have found the issue. I believe the black shield behind the timing belt has a 90 degree bend in it and one of the bolts went through it. (The shield on the passenger side has a similar bent that a bolt goes through.)
Hopefully if I can bend the tab back it will free up the manifold. Fingers crossed
Looks like the driver's side cover is secured by the timing belt tensioning spring mechanism.
Looks like simply bending the tab didn't work.
Has anybody removed the driver's side rear timing belt cover?
- 124JOE
have a look
some guys remove them all
theres many different styles
back in the day a mecanic wouldnt even put it back on if having to remove it
- Wheel
- Your car is a: 1982 Fiat Spider
it slides off, i had the same problem and it finally came off, it like a hook open slot i belive
