76 spider brake block
bwhipple
Post by bwhipple »
Just got a 76 fiat spider with no brakes. Filled her up with fluid and I have a leak coming from a 4 port block with a wire coming from it. I cant seem to find this part for sale anywhere. Is there a work around to eliminate it? Thanks.
vandor
Re: 76 spider brake block
Post by vandor »
Hello,
That part turned on the dash brake light if the pressure between the 2 circuits was different. After '77 that was eliminated in favor of a float with a switch in the reservoir.
You can eliminate that block by:
-Replace it with a solid one that simply has straight holes between the tubes and no switch (I may have one)
-Remove the block, route the rear hose straight to the master cylinder, and use a left front brake line from a later Spider (I may have that aswell).
bwhipple
Post by bwhipple »
I think I will just replace it with a 4 port block with no switch. Can you provide pricing and availability on this. Thanks.
vandor
Post by vandor »
bwhipple wrote:I think I will just replace it with a 4 port block with no switch. Can you provide pricing and availability on this. Thanks.
Hi, please message or email me, so I get reminded to look for it when I get home this evening.
johndemar
Your car is a: 1976 Fiat 124 Spider
Post by johndemar »
If the leak is coming out of the port for the wire sensor, JB Weld would solve the problem. That's where I developed a leak, and not being able to find a replacement, I just sealed it up. That was over 3 years ago and no leaks.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
124JOE
Post by 124JOE »
i would re do all the lines, a master, a rear block, hoses
thats what they ended up with
start with the bleeder screws
when you do every thing right...
manoa matt
Post by manoa matt »
I have the block with the sensor, no leaks, and a few of the hard lines that come from it. Send me an email if interested. matt.scarton@gmail.com
