ITBs?
- Your car is a: 1975 Spider
Re: ITBs?
those are the itb's ive seen, if i get the nerve i might get those and try a megasquirt, im so unsure of my maping ability, thats the reason im shying away from it
son has 78 spider
son has 78 spider
Re: ITBs?
Redline has a similar setup. Jeff Scheferman has/had the system on his 72 Coupe.
Re: ITBs?
All things being equal ITBs and Carbs will be the same power Turbo or supercharging would provide
far more power if done correctly . The advantages of ITBs and EFI is tuning on the spot without changing
and buying a collection of jets . Redline's ITBs are Webers btw a good choice imo .
Re: ITBs?
What a terrible website! maybe try calling them to see what they have to offer.
- manoa matt
Re: ITBs?
The injectors are in the throttle bores of the ITB's. The ITB"S bolt onto an intake manifold designed for dual carbs. Pierce manifolds has the manifold for around $260.
Re: ITBs?
you could buy a manifold from Pierce or just find a used IDF Fiat Manifold which is better then the
PBS Produced Intake Manifold that they would sell you . The ports have a 90 degree bend in them
which if you compare side by side you'll notice smoother curve on the Factory Fiat unit .
Last time i called redline they didn't even have someone to answer the phone it was some sort
of answering service .
You could use the Fiat FI manifold with a Mega Squirt to control and manege everything
that would save you about 1400 bucks on ITBs cost alone .
- Your car is a: 1970 128
Re: ITBs?
Re: ITBs?
Yes i am completely aware of this that is why i said all things being equal ! if you try to using large venturies you lose a lotDaniel, that's part of the reason why ITB's will always be more powerful than carbs... not the same... as a throttle body doesn't require fitment of a venturi (primary or secondary) to speed the airflow and issue the fuel from which a carburettor requires to function... these are again obstructions to the flow path that are simply not there on a throttle body, hence they will flow more air for the same body size and make more power, no ifs or buts.
of drivability do to the low vacuum that is needed to make the Jet circuits work well within the venturie area but thanks .
I've built race Fiat engines in a number of different configurations most of them have been carbs, first set were Mikuni
side drafts then Delortos and last but not least Webers . After realizing how hard it was to come by jets for the first 2 sets
of carbs i went for the Webers lesson learned .
I like your Intake Valve weight reduction it's a nice mod i may copy that on the next engine i build .
