ITBs?
Zmatt
ITBs?
Post by Zmatt »
http://www.extrudabody.biz/servlet/the- ... Kit/Detail
I just saw this today after some bored searching. Anyone ever tried this kit before? what are your thoughts?
BEEK
Your car is a: 1975 Spider
Re: ITBs?
Post by BEEK »
those are the itb's ive seen, if i get the nerve i might get those and try a megasquirt, im so unsure of my maping ability, thats the reason im shying away from it
75 spider
son has 78 spider
mdrburchette
Re: ITBs?
Post by mdrburchette »
Redline has a similar setup. Jeff Scheferman has/had the system on his 72 Coupe.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
Zmatt
Re: ITBs?
Post by Zmatt »
Could you link to the redline kit? I think it's an interesting path. Wouldn't be as powerful as forced induction, but if you want EFI and want the response and sound of the carb then it seems like a good choice. ITBs sound and feel great.
Daniel
Re: ITBs?
Post by Daniel »
All things being equal ITBs and Carbs will be the same power Turbo or supercharging would provide
far more power if done correctly . The advantages of ITBs and EFI is tuning on the spot without changing
and buying a collection of jets . Redline's ITBs are Webers btw a good choice imo .
wmausbach
Your car is a: fiat 124 spider
Re: ITBs?
Post by wmausbach »
Daniel,
ITB's are not magic , why do you think they can outperform a Turbo. Fiat didn't when they ran their rally cars. They went to supercharging and then Turbo after going the ITB route.
Ciao
Wayne
Zmatt
Re: ITBs?
Post by Zmatt »
I think you misread his post. He said carb power =itb and turbo\sc > then both.
Zmatt
Re: ITBs?
Post by Zmatt »
So I found the redline weber site. Aside from most fo the site being broken and looking like it's form 1998, I couldn't find a fiat specific kit. So I guess you would have to build you own using their carbs?
mdrburchette
Re: ITBs?
What a terrible website! maybe try calling them to see what they have to offer.
Zmatt
Re: ITBs?
Post by Zmatt »
yeah, there isn't much to see there. I just had a thought. That ITB kit I posted wants you to use an aftermarket carb manifold, makes sense but those aren't drilled for MPI, so where do the injectors go? do you have to do that yourself?
manoa matt
Re: ITBs?
Post by manoa matt »
The injectors are in the throttle bores of the ITB's. The ITB"S bolt onto an intake manifold designed for dual carbs. Pierce manifolds has the manifold for around $260.
Zmatt
Re: ITBs?
Post by Zmatt »
so it isn't MPI, it's TBI? Well that makes it little more than an electronically controlled carb. Aren't the factory FI 124's port injected?
Daniel
Re: ITBs?
Post by Daniel »
you could buy a manifold from Pierce or just find a used IDF Fiat Manifold which is better then the
PBS Produced Intake Manifold that they would sell you . The ports have a 90 degree bend in them
which if you compare side by side you'll notice smoother curve on the Factory Fiat unit .
Last time i called redline they didn't even have someone to answer the phone it was some sort
of answering service .
You could use the Fiat FI manifold with a Mega Squirt to control and manege everything
that would save you about 1400 bucks on ITBs cost alone .
fiatfactory
Your car is a: 1970 128
Re: ITBs?
Post by fiatfactory »
Daniel
Re: ITBs?
Post by Daniel »
Daniel, that's part of the reason why ITB's will always be more powerful than carbs... not the same... as a throttle body doesn't require fitment of a venturi (primary or secondary) to speed the airflow and issue the fuel from which a carburettor requires to function... these are again obstructions to the flow path that are simply not there on a throttle body, hence they will flow more air for the same body size and make more power, no ifs or buts.
Yes i am completely aware of this that is why i said all things being equal ! if you try to using large venturies you lose a lot
of drivability do to the low vacuum that is needed to make the Jet circuits work well within the venturie area but thanks .
I've built race Fiat engines in a number of different configurations most of them have been carbs, first set were Mikuni
side drafts then Delortos and last but not least Webers . After realizing how hard it was to come by jets for the first 2 sets
of carbs i went for the Webers lesson learned .
I like your Intake Valve weight reduction it's a nice mod i may copy that on the next engine i build .
