ITBs?
- Your car is a: 1970 128
Re: ITBs?
- Your car is a: 1975 Spider
Re: ITBs?
why not titanium valves, if thats the case, wonder if a 7mm stem can support a 43.5mm head
son has 78 spider
son has 78 spider
- Your car is a: 81 spider
Re: ITBs?
"you could buy a manifold from Pierce or just find a used IDF Fiat Manifold which is better then the
PBS Produced Intake Manifold that they would sell you"
How do you know the Fiat mani is" better" the a PBS I have found that bothPBS and Fiat waffle manifolds need to be cleaned up and gasket matched. Port sizes are similar if anything the PBS mani is a little more compact without the water jacket.
Chris
Oakland, cA
Chris
Oakland, cA
Re: ITBs?
The Fiat IDF Manifolds 90 degree port Curve isnt as sharp a bend as the PBS and the ports are nicer,How do you know the Fiat mani is" better"
the ones i've worked with have been any how . Plugging the water port fittings isnt hard to do if that
was something you didn't want or need .
