Air conditioning
wapolo3
Air conditioning
Post by wapolo3 »
I just bought an 83 spider with 43,000 original miles on it. It has air conditioning, which does not work. I'm sure this is a common problem, a friend of mine who is a mechanic took a quick look at it and traced the problem to a relay. My question is where is the air conditioning relay in an 83 spider.
how did the mechanic verify the bad relay without finding it?
wapolo3
Post by wapolo3 »
Mark
The mechanic was up in northern california and looked at the vehicle before I picked it up. I did not spend alot of time asking the questions about the air conditioning as I should have. I just spoke with him and he told me that it's charged and somehow he got the compressor working but the problem was electrical and traced it back to the relay. I did not follow up and ask where the relay was. I would like to start there first and then work my way up to the more expensive stuff.
Thanks for your help
