What's this nut?
stuartrubin
What's this nut?
Post by stuartrubin »
I found this nut on the floor on the driver's side. Most of guts around the steering wheel, ignition, pedals, etc. are exposed (not covering), so it could have come from anywhere.
It's sort of a strange shape with a normal looking threaded hole, but knurled, almost gear-like outer diameter.
Anyone know where this goes?
Thanks!
Stuart
1975 FIAT 124 Spider
Il Mostro di Frankenstein
lglade
Re: What's this nut?
Post by lglade »
Each gauge is held to the backside of the dashboard with one or two metal clamps. That looks like one of the nuts that attaches the clamp to the gauge.
http://ebayapi.loc8apartltd.netdna-cdn. ... fQ~~_1.JPG
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
joelittel
Post by joelittel »
I agree
stuartrubin
That makes sense. My dashboard is a mess, too!
Thanks, guys!
Stuart
lglade
Post by lglade »
You can pull the steering wheel and then drop the steering column about half an inch by loosening the bolts on the underside of the dash. This makes it easy to pull the whole dashboard out. Total time is only about fifteen minutes, and you'll have a chance to clean up most of that mess, tighten loose nuts, and replace old bulbs, etc.
2015 Subaru Outback
2017 Ford Focus RS
