Leaking diff
markee
Your car is a: 1977 124 SPIDER 1800
Leaking diff
Post by markee »
TX82FIAT
Re: Leaking diff
Post by TX82FIAT »
What year is your car. Before going further the later model spiders have a vent cap above the axel on the drivers side. Depending on the fluid level in the diff and how hard you corner splashing things around this will leak out the top and travel towards the diff. It will look like a leak at the axel by the pumpkin if your not aware of the vent cap. I only say this because I scratched my head for a week trying to figure out why my diff was leaking in that spot only to come up with a little overspill from the vent cap.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
markee
Re: Leaking diff
Post by markee »
TX82FIAT
Re: Leaking diff
Post by TX82FIAT »
Not sure how the set up is on the 77. I think 78 - 82 use one type and that same type may be OK for the 83-85. I know thoase years do have a vent cap. If you go above the axel on the drivers side and start at the pumpkin with your hand on top of the diff moving towards the drivers side whell you will feel a 1/2 inch round bump a few inches from the differential. If you have it on your car it may be covered with a lot of grim. That 1/2 inch bump will be your vent cap if you have one.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
markee
Re: Leaking diff
Post by markee »
markee
Re: Leaking diff
Post by markee »
124JOE
Re: Leaking diff
Post by 124JOE »
clean it all up empty the fluid
replace with new gaskets and fluid
and watch for a leak
im not saying theres gaskets where you see the leak
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Re: Leaking diff
Post by adrians »
Degrease and clean up the diff housing, let it dry, then 'puff' talcum powder or similar around the diff. Go for a drive then see where the oil has leaked from or spilled from.
THE FLEET
2014 Abarth "SS"
Exit98
Re: Leaking diff
Post by Exit98 »
Talcum powder on a rear end.
Sounds like a good idea to me.
adrians
Re: Leaking diff
Post by adrians »
Exit98 wrote:Talcum powder on a rear end.
Makes for a smooth operation :) :)
THE FLEET
2014 Abarth "SS"
124JOE
Re: Leaking diff
Post by 124JOE »
WOW :shock: :shock: :shock: :shock: :shock:
TX82FIAT
Re: Leaking diff
Post by TX82FIAT »
If I say the Talcum powder on the rear end is a great idea does that change any of my political views? Seriously, it is a simple and effective way to find a leak.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
adrians
Re: Leaking diff
Post by adrians »
TX82FIAT wrote:If I say the Talcum powder on the rear end is a great idea does that change any of my political views? Seriously, it is a simple and effective way to find a leak.
Yep - It was the only way I could find the hair line crack on the sump, were the sump plug was welded to the sheet metal.
THE FLEET
2014 Abarth "SS"
redcars
Re: Leaking diff
Post by redcars »
I use spray on foot powder to find leaks.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
124JOE
Re: Leaking diff
Post by 124JOE »
i think he left us
