I picked up a $5.99 chain wrench at Harbor Freight today and wrapped it around the outer pulley (with a section of old belt in the groove). With a breaker bar on the chain wrench wedged against the underside of the car (it has a receiver for a 1/2" socket wrench) and a 1/2" socket wrench and 4' cheater on the crank nut it turned like butter. A 30 second job and much less nerve wracking than the ghetto starter method.
Now on to the cam, aux and crank seals, timing belt and water pump.
Oh and I think I figured out my cold start problem but I'll wait to follow up on my old post when I have the car together and can test it.
FYI - crank nut removal
burlybryan
'82 Spider 2000 FI
'12 500 Sport (Verde Oliva) - wife's daily driver - when it's not being fixed at the dealer...
'82 Spider 2000 FI
Re: FYI - crank nut removal
Berek wrote:Sounds like you needlessly spent $5.99 lol
burlybryan
'82 Spider 2000 FI
'82 Spider 2000 FI
Can you post a pic of the "setup" as you described it.
well Berek If he wasted 5.99 then how would you do it ?
In the so called ghetto fashion lol deep well and a breaker bar to the deck turn the key and hit starter button.I have done that with every vehicle I have ever had to remove the damper or crank pulley on. Don't understand how it is ghetto..but ok.
- bradartigue
Because if you orient the breaker bar the wrong way it will take that wrench and bust the sh*t out of your fender, hood, face, or all three. For $5.99 the man made no mistakes.Berek wrote:In the so called ghetto fashion lol deep well and a breaker bar to the deck turn the key and hit starter button.I have done that with every vehicle I have ever had to remove the damper or crank pulley on. Don't understand how it is ghetto..but ok.
1970 124 Spider
http://www.artigue.com/fiat
