Engine Dies
jsdieter
Engine Dies
Post by jsdieter »
My car has the 1800 engine with the 32 ADFA and it likes to die when I come to a stop. It does it intermittently but it dies more than it wants to idle. When it does like to idle it is smooth and just under 1000rpm. I am wonder if it is dying because it is being starved of fuel because if you feather the throttle you can keep it running. It has a new fuel filter. Or could it possible be the idle solenoid? Thanks for the help.
vandor
Re: Engine Dies
Post by vandor »
It could definitely be the idle solenoid. Make sure the wire is on the firmly and making good contact.
Also make sure the solenoid is screwed in tightly.
jsdieter
Re: Engine Dies
Post by jsdieter »
Alright I will check all that Thanks!
124JOE
Re: Engine Dies
Post by 124JOE »
i had a problem like that
it was the main ground "loose"
also it might be the ingnition"dirty contacts"
and i have the fireball ign that removed the points
it developed a short right where it went into the dizzy"i taped it"
