Radiator Pipe Soldering Question.
Would it be difficult to put a new overflow outlet pipe on my radiator as it's kind of rusty? It's just soldered on, right?
- Your car is a: 1970 SPIDER AND A 1976 SPIDER
Re: Radiator Pipe Soldering Question.
If you are going to go to a radiator shop let them do it. I would get your radiator boiled out. and have them check it for leaks. I used Fingers here in NJ and they did a great job. George
- SLOSpider
- Your car is a: 1973 124 Spider 2.0FI
Id just get some sandpaper and clean it up unless its really loose
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
What's an approximate fee do most rad places charge for hot tanking?NJFIAT1981 wrote:If you are going to go to a radiator shop let them do it. I would get your radiator boiled out. and have them check it for leaks. I used Fingers here in NJ and they did a great job. George
- SLOSpider
I paid $95.00 to have it boiled and flushed out, some leaks around the tank fix and solder back on the side to support.
1975 124 Spider
