Want to remove the windshield with its frame from the parts car. Is it as easy as removing those four bolts and pulling up?
Anything to watch out for?
From Manoa Matt
... I've replaced two windshields and removed and replaced two frames in the three years I've had my car (don't ask, long story) I've learned something each time and it gets easier, however cracking the windshield is a possiblity when re-fitting the assembily, and the more you take it apart and move it around the more likely.
Get two friends and loosen the bolts on each side of the frame. The top nut is welded to the frame, so the top bolt on either side will just unscrew. The bottom bolt on each side is a true nut and bolt, so upon removal you need to keep the nut from spinning. I usually remove the lower bolts and loosen the uppers and when ready just unscrew the last few threads.
Have a person on each side loosen and remove the bolts. Once the bolts are removed the person on each side will pry out slightly and slide up the frame. The glass and gasket should stay where they are.
