Bolt size?
Schnauzer
Bolt size?
Post by Schnauzer »
What is the bolt size and length for the lower alternator mounting ear. This would be the thru bolt that goes through the mounting bracket and lower ear on the alternator. I discovered this missing while replacing the timing belt last weekend. I'm hoping that some one has their engine out and can check this easily. Thanks for the help.
Jim
manoa matt
Re: Bolt size?
Post by manoa matt »
I've got a couple of them. Let me know if you are interested. matt.scarton@gmail.com
Schnauzer
Re: Bolt size?
Post by Schnauzer »
Email sent Matt: Just need the specs. Not worth the shipping cost over the water to North Idaho.
azygoustoyou
Re: Bolt size?
Post by azygoustoyou »
The mounting bolt is 5 1/4 x 7/16. This would be from end to end including the head.
