Unknown connection. Need some help with this one.
Mark_vaughn
Post by Mark_vaughn »
I have a connection on my intake manifold about center of it on top. It is two hose connections. I think it may be coolant, but not sure. Mine are not connected to anything at the moment.
Anyone know what these are and where they should be connected to?
I have a picture, but I don't know how to upload it here.
It is a '77 model 1800, basicly stock. I think they took all the emission stuff off years ago.
Mark
that is a thermal switch that was in series with the egr valve. It prevented the egr valve from opening until the water temp was about 100F. It does go into a water jacket, so you'll need to plug the opening if you decide to remove it.
Mark_vaughn
It has already been removed I guess. I found the connections when I removed the carb.
The car seems to run fine without it. Is the removal of this connection the first step in blowing up your engine?
Jim DeShon
Post by Jim DeShon »
Removing it won't hurt a thing. I wish I could get rid of all that crap on mine but the lovely State of California says no ! I'm thinking of building up two different head/manifold/carb assemblies, one for the smog test and one for the rest of the time. ...J.D.
TVST*R
Post by TVST*R »
Jim DeShon wrote:Removing it won't hurt a thing. I wish I could get rid of all that crap on mine but the lovely State of California says no ! I'm thinking of building up two different head/manifold/carb assemblies, one for the smog test and one for the rest of the time. ...J.D.
Uh..Yeah!
Jim DeShon
I have a complete smog legal 1800 (49 state) setup. I need to find another head to build. ...J.D.
