I want an agressive street motor, 135-140 horsepower or so seems to be a realistic target from what I've been reading. Needs to be realiable, not a daily driver but I don't want to have to spend hours and hours wrenching to keep her running right.
Plan so far is: Slight overbore, possible domed pistons for increased compression. Cams - getting all kinds of differing info here, but sounds like fairly agressive intake cam and mild or stock exhaust cam will work well. Valves - undecided, had planned at a minimum racing springs. Carb - Since I have "the best stock carb" is the performance gain from a dual set up worth the cost of the intake and the carbs, or would a rebuild(with venturi overbore) and rejetting be close enough to the dual set up? Ignition - goodbye points. Crane 700 unit or other - suggestions? Flywheel will be lightened. Exhaust - performance header and exhaust.
I know the different combinations and options for engine builds are almost endless, but please fire away with any and all suggestions!
I would also appreciate any suggestions for sourcing the necessary parts.
Thanks to all
Kevin
