Aftermarket wheels
Aftermarket wheels
I haven't purchased wheels for the '72 Spyder in 20 years. I'm looking to replace the existing wheels. Most that I find are 4/100mm bolt pattern. The bolt spacing on the Spyder is 4/98mm. Does anyone have information on what wheel companies carry a compatable wheel?
- ga.spyder
Re: Aftermarket wheels
All years of the Spider use 4x98 wheels.All of our vendors sell wheels for Fiat application.Bayless had a sale running recently,but check Vicks,Bruces Parts bin,IAP,etc..There is a current post on some Rota wheels on ebay.All vendors should have 13'',14'',and 15'' sizes.I have 15x7 Team Dynamic wheels w/ 205x55-15 Kumho tires.I like the wide tire look,others don't. Heres a pic
there are wheels w/ tires in ''parts for sale'' section
Craig Nelson
Fling It Around Turns !
I have considered having mine redrilled to a 4x100 pattern so I can use normal wheels. The savings on the wheels might make up for the machine work.
Trey
This may be a better option. It will get you to the more popular 4x100 w/o machining. https://adaptitusa.com/index.asp?PageAc ... &ProdID=26htchevyii wrote:I have considered having mine redrilled to a 4x100 pattern so I can use normal wheels. The savings on the wheels might make up for the machine work.
I've seen the adapters as well as the "wobble bolts" that allow you to use 4x100 wheels :http://www.serpentautosport.com/HTML/Hu ... acers.html
But I don't think either is a very good solution.
Trey
- ga.spyder
I have had bad experience with adapters,albeit on off-road Jeeps.It might not be as bad on the Fiat,although I would rather not have them on mine.
Craig Nelson
- TulsaSpider
Wow that looks great!ga.spyder wrote:All years of the Spider use 4x98 wheels.All of our vendors sell wheels for Fiat application.Bayless had a sale running recently,but check Vicks,Bruces Parts bin,IAP,etc..There is a current post on some Rota wheels on ebay.All vendors should have 13'',14'',and 15'' sizes.I have 15x7 Team Dynamic wheels w/ 205x55-15 Kumho tires.I like the wide tire look,others don't. Heres a pic
- ga.spyder
Thanks,I have to pass that view all the time.I live in the valley below there,a few miles down.
Craig Nelson
Ya know Craig, those clouds havent moved in the background in the last year. I think its a painting on a building! Still love the color of the car.
- ga.spyder
What are you sayin', Pope? I need to freshen my portfolio
I love that picture of the car,and I pass that overlook all the time.On a whim,I just stopped one day and snapped a pic.I wanted to use it for our Christmas cards....uh,the wife wasnt amused!
Craig Nelson
- Your car is a: 2 1977 124 Spiders 1969 124 Coupe
wow, I was at work when I saw that picture and I sort of started daydreaming. ALmost got in trouble ! Beautiful view and a beautiful car!
Just put on some wobbly bolts and a hub ring and you can use any 15" wheel out there with a correct offset. I use them for years.
