High Performance ignition module
ga.spyder
Post by ga.spyder »
I am curious if anyone has installed a high perf. ign. module on their F.I. Spider? There is one listed in the Vicks catalog,for around $100.I wonder if the results are worth the money.I have installed these units in other makes with pretty good results,usually with a hotter coil.I am all for bolt on performance,especially on the F.I. cars where upgrades are limited.
Craig
Craig Nelson
Fling It Around Turns !
Re: High Performance ignition module
I've used a couple of them, but not what Vicks' sells, and had good results. Along with an e-coil it creates a great spark with higher revs
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
I'd like to hear more details about this. I am a "keep it original" kind of guy, but a little more pep might help me keep up with Ace on the runs.
Ron Luxmore
rlux2n2@gmail.com
manoa matt
Post by manoa matt »
Summit sells that Accel ignition module for around $40 Summit part # ACC-35361
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
I got a Accell coil & module off Ebay, paid $50-60 for both. I don't know if they helped performance, but they look better :)
The MSD one is supposed to be the best.
Trey
mdrburchette
Post by mdrburchette »
I'm running the MSD box with Blaster II coil on my 72 and the original 79 model setup with GM module on my 71. It's hard to determine which is best since my cars are completely different. I doubt paying more for a better ignition system would help my poor ole 71 :cry: but I had my 72 dynoed before and after the engine rebuild and swap to the MSD. At around 6200 rpms the chart showed irratic ignition issues before but was more consistant after.
ga.spyder
Post by ga.spyder »
This is something I am going to look into,thanks for the feedback.Mark,what is a e-coil...brand name or a type of coil? I see several 'hotter' coils for fairly cheap,any reccomendations on type or brand? I will look into my Summit catalog,thanks for the part no., Matt.
Thanks, Craig
Craig Nelson
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
I think the e-coil is a factory Ford coil, but for what I don't know. Here's the Mallory replacement: http://www.dragracingonline.com/itsnew/iv_8_1.html
Trey
henry
Your car is a: Pininfarina 1983
Post by henry »
Can this module be install to a 1983 Pininfarina?
Thank you.
ga.spyder
Post by ga.spyder »
Henry, it can be installed in your car.I bought the module and an Accel coil from Summit Racing.Truthfully,I cant really tell much of a difference. After running the module for a few weeks ,it failed..quit..gone. Had a time figuring out what was wrong.I have the stock module back in,and I bought a spare for $20 at Autozone.
Craig
Craig Nelson
