His battery is good ,,his battery cables are good ,,his fuses are good ,,his wires to the plugs are good .... He can start it either by compression with the clutch while rolling or turning the key off and restarting it and it will go awhile and then quit . Mile or two in between or some times more than that before it quits.. Ignition maybe ??
Here are before and after pictures from when we buffed it out a couple weeks ago .. Oxidized pretty bad.. LD
CLICK TO ENLARGE
