Haven't been here in a while. Quick question. Car is a 1977 Spider. I took out and rebuilt the transmission years ago so I should know this.
Now I think I have driveshaft issues, maybe the center bearing or a universal. Something made a scary noise last time I drove the car.
If I unbolt the shaft from the differential and unbolt the piece holding the bearing, get the e-brake out of the way, should the driveshaft pull out of the transmission with some kind of splined piece on that end or do I need to unbolt the Guibo or something else up there?
thanks!
Drive shaft
- Nanonevol
Drive shaft
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- Nanonevol
Re: Drive shaft
Never Mind!
Driveshaft is out. No need to unbolt at the transmission.
Looks like my pillow bearing( is that what it’s called?) is lunched.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- Patron 2021
Re: Drive shaft
Brought mine to a axle driveshaft shop, Had the u joints replaced as well.
