Turtleback air filter clearance
- Your car is a: 124 CS1 Spider
Hello all, any advise on a 1976 small bumps bonnet car with a 2l engine. I understand the 2l engine is higher so there is not enough clearance for the turtleback is this correct? Thanks in advance for any experience shared.
if you're not scraping skin when fettling, you're not trying hard enough
- MattVAS
- Your car is a: 1976 Fiat Spider 124
Re: Turtleback air filter clearance
You may need to run the EARLY engine mounts to gain a little extra clearance.
Vick Auto SKU 57-9307
Matt Phillips
Vick Auto - Manager
http://www.vickauto.com
Vick Auto - Manager
Thank you, but the part number does not yield any results on your site.
I think he means this one, but you should check with them to verify:
https://www.vickauto.com/FIAT-PARTS/FIA ... KU-57-9300
