Air intake hose
- Your car is a: 1985 Pininfarina
Air intake hose
I have recently bought a Pininfarina Spider Europa 1985.5 - There is a small hose that is connected to the engine air intake and just laying in the engine bay not connected to anything, after much searching I have discovered that this is meant to be connected to the vacuum advance on the distributor except there isn’t a vacuum advance module on the distributor?
Any clues if this set-up is correct and advice would be much appreciated.
Thanks Michael
Thanks Michael
Re: Air intake hose
Also, meant to say that the acceleration is erratic at low speed and struggles when going uphill??
Re: Air intake hose
"Any clues if this set-up is correct and advice would be much appreciated. "
Well, it's not correct in the sense that it isn't factory. But that doesn't mean it can't function.
Make sure the hose at the intake is plugged. If it's open, that could explain your symptoms.
Re: Air intake hose
Thanks for the info - maybe, I need to look at a new distributor, the tube is open so will plug it and see it that helps things. Thanks again, Michael
Re: Air intake hose
Lack of vacuum advance in ignition hurts low speed torque and drivability.
Re: Air intake hose
Thanks for your help - it’s a nice day tomorrow so out for a drive and going to plug that hose and see if it makes any difference - Again thanks for the knowledge
- Patron 2021
Re: Air intake hose
Which years did not have vacuum advance?
Re: Air intake hose
1978 and earlier, but I hope someone will jump in and correct me if I've got this wrong. So, only the 2L engine had vacuum advance.tima01864 wrote:Which years did not have vacuum advance?
Re: Air intake hose
Any engine will benefit from adding vac advance to ignition. It improves off idle torque, low speed performance.
I added it to my 1800 a few years back and it made a huge difference when driving in the neighborhood.
It does require a steady vacuum signal, preferably a common plenum intake. It can be done with IDFs but it takes some engineering to smooth out the vac signal. I have it now with dual IDFs and could share ideas.
Re: Air intake hose
Hi, I have been researching new distributors - has anyone installed or had experience with the ‘123ignition’ distributors?
Re: Air intake hose
They suck.MBEpse wrote:Hi, I have been researching new distributors - has anyone installed or had experience with the ‘123ignition’ distributors?
Just get the '79 dizzy from AR, a $15 GM HEICU and a heatsink. Works great.
Re: Air intake hose
Thanks for the honest reply!
I did speak to a company that sells these distributors and they wouldn’t recommend using on my car so will look at AR, Vic’s and some of the german sites for a ‘standard’ distributor with vacuum advance.
Thanks for the advice.
Re: Air intake hose
Hey Steiny, what’s this GM “HEICU” and heat sink setup you speak of? Just curious...
1981 Fiat Spider 2000
2011 BMW 335i M-Sport
1971 Honda CB450 Twin
Re: Air intake hose
I'm not so sure the 85.5 distributor used a vacuum advance. I also don't think any turbo charged engines used a vacuum advance. Hopefully someone with documentation or owns an 85.5 can confirm one way or the other. I think I recall someone mentioning the 85.5 used a unique distributor.I have recently bought a Pininfarina Spider Europa 1985.5
Re: Air intake hose
Thanks for the information - I will try a bit of research.
