timing cover and fuel pump question
warrenrhen
Your car is a: 1979 fiat 124 spider
Post by warrenrhen »
OK I'm new to this car and this forum, so I have some simple questions. First the timing belt cover. I have the front of the cover off anf the back side of it on the passenger side off but something is holding the driver side off. My other question is about the left (driver side) of the block. What appears to be a fuel pump. Gass lines going to and from. Is this a fuel pump or just a storage unit to keep fuel from flowing back to the tank. I'll obviously have many more questions later. Thanks
Warren
Cheers, Warren
79 124 spider
18 Dodge Charger R/T
20 Vespa 300 GTS HPE
Nut124
Re: timing cover and fuel pump question
Post by Nut124 »
Are you talking about the yellow plastic cover? There are just 3 or 4 long bolts holding it down. You should be able to see them. One is way down on the driver side.
The mechanical fuel pump is mounted on the block on the left side.
warrenrhen
Thanks for the tip on the mechanical full pump. I wasn't sure they had one. I read somewhere that they had a one way valve or holding canister to keep the from from running away from the carb causing hard starting. As for the cam belt cover. I have the yellow part off the front of the cam pulleys. I also have the black backside of the cover off the right side but the one on the left doesn't want to come off. How many bolts should be holding that on?
Cheers, Warren
79 124 spider
On the question of a one-way valve or holding canister, you may be thinking of the vapor canister, which is used to capture gas vapors from the carb and the gas tank, and then bleed them back into the intake rather than just vent them to the outside atmosphere. Some people do install a one-way valve on the fuel line to the carb, but it wasn't stock that I'm aware of.
On the timing belt cover, I vaguely recall that later models had a metal shield on the rear face of the front cover, and that the metal shield came in two or more pieces. Take a look at the pictures on this webpage (and the 2 preceding ones) and see if you can identify what you have, and perhaps you can zoom in and see where the bolt holes are.
http://www.fiatplus.com/TIMING-BELT-COV ... TS/?page=3
TX82FIAT
Post by TX82FIAT »
You might also be thinking of the fuel pressure regulator that is part of the fuel rail.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Post by RRoller123 »
On the timing cover, I think you may be referring to the INNER timing belt cover? That sits up against the front of the engine, completely encloses the timing belt (ridiculous overkill) and has usually been removed (and NEVER replaced) on most cars. It is one piece, metal, and only can come off I believe if the Crank Pulley comes off.
wetminkey
Post by wetminkey »
Actually, multipiece, but just as Roller states, it is 'overkill', is usually removed, and the crankshaft nut must be removed to remove the 'tins'. I'm quite glad that I did, for a couple of reasons,...timing belt can be replaced, in the future, without removing the nut again,...for one!
In any case, welcome and best of luck with your new-to-you car!
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Thanks for clarifying, my car already had it removed when I got it. (Thank God).
Lckitty
Post by Lckitty »
This may help.
https://www.middlebartongarage.com/Imag ... Covers.jpg
Middle barton garage has great diagrams.
Current Stable: Lotus Evora, Fiat 2000, Jeep Grand Cherokee, Jaguar XF-R
