Pertronix spark plug gap
- Zoofly
I'm going to change out my spark plugs. This will be the first time I've changed them since I installed a Pertronix electronic ignition in my distributor about 3 years ago. My spider is a 78 and the spark plug gap is 0.6-0.7mm (non-resistor) and 0.7-0.88mm (resister) according to my Clymer manual. First question is what's the difference between non-resistor and resistor? Second question is, should the spark plug gap be different now that I'm running an electronic distributor instead of points? Any insight would be helpful. Thanks
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
1998 BMW Z3 - sold
Re: Pertronix spark plug gap
The resistor plugs have an inline resistor to help suppress radio noise production.
Non-resistor spark plugs are not used much anymore, both for the radio noise issues as mentioned above by RRoller, but also because the radio frequency interference (RFI) on non-resistor plugs can also affect the sensitive electronics of modern cars. However, you can still buy non-resistor plugs; for example, the Champion spark plug website suggests either a N9YC (non-resistor) or an RN9YC (the resistor version) for the spiders. In these older cars, you could use either, but I would use the resistor version. The guy at the stoplight next to you in the 2020 model car might appreciate it, even if it doesn't make a huge difference in your Fiat. Note that FM is less sensitive to RFI than the AM bands. Same reason as with lightning storms.
As for the plug gap, I think that is mostly a function of your coil. If your electronic ignition still uses the original coil, I would go with the original specs for spiders, which is somewhere in the vicinity of 0.023" to 0.027". Fully electronic ignitions including a new coil might be larger, and if that's the case, I would consult the manufacturer of the electronic ignition. I usually just set mine to 0.025" (about 0.64 mm) and forget about it. But, then again, I'm old school with points and condensers.
+1
Running Pertronix and blue Bosch coil for 10 years with standard plug gap. The module only affects the timing of the spark, not the strength.
- Zoofly
I'm running the Flamethrower coil, so I'll go with the recommended gap for OEM. Thanks for the replies.
1998 BMW Z3 - sold
1998 BMW Z3 - sold
- MattVAS
- Your car is a: 1976 Fiat Spider 124
JOKE POST!!!!
87753OOOOOOOOONINNNNNNNE
Matt Phillips
Vick Auto - Manager
http://www.vickauto.com
Vick Auto - Manager
Jenny, Jenny, who can I turn to???
- aj81spider
You'll never get her that way. You're calling the wrong number.
It's 867-5309
It's 867-5309
A.J.
2006 Corvette
2006 Corvette
Yeah, I noticed that!
Probably need the area code, too!
Tommy Tutone, aka Bryan
For those that haven't gotten the joke: https://www.youtube.com/watch?v=6WTdTwcmxyo
