Gauge cluster swap
- Zoofly
Gauge cluster swap
Without posting pictures, I'll try to describe what I'm wanting to do. I had a custom instrument cluster made and installed at Allison's. Mark added an Oil Pressure Gauge which my '78 didn't have. That new gauge has a different design than my Gas and Temp gauges. The Oil gauge has yellow writing and also Italian description of the gauge, "Olio". The needle pivots from the top of the gauge, compared to my Gas and Temp gauge with the needle pivoting from the bottom. I'd like to have my Gas and Temp gauge in the same design. I was able to find the Gas and Temp gauges on eBay that match my Oil gauge. My question: Is it a simple swap? No re-wiring of the pigtails, just plug in the replacements? Or am I looking at a bigger project?
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
1998 BMW Z3 - sold
- dinghyguy
- Your car is a: 1981 spider
Re: Gauge cluster swap
they work fine, Benzina and aqua, together with Olio. only thing is to make sure the position of the pins in the plug is correct for your wiring. Given the changes that often happen to old cars i would get the wiring diagram from Mira and then check that the new ones match up. when they do, plug in and play. I have done both my fiats exactly like that.
cheers
dinghyguy
cheers
dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
