During the last research in the german "the big Spider book" I noticed again the official FIAT anniversary photo, which is supposed to show the 200,000th Spider.
But how could this work, when the known sources write mostly of about 198,000 Spiders. In order to get to the bottom of the matter and to approach the true production number, the worldwide Spider registry can be used. To do this, it is important to know that FIAT has performed sequential numbering across types. The BS/BS1 Spiders follow directly to the AS, the CS/CS1/CSA directly or even overlap to the BS1 etc. However, Italian was counted and there are gaps in numbering (e.g. for a new manufacture year).
In order to limit these gaps, the vehicle identification, chassis or serial numbers in the registry, which now includes more than 14,600 vehicles, were evaluated in increments of 100. Some gaps seem to exist, many of which are probably due to a lack of documented vehicles.
Hereby I need your help: Who owns or knows vehicles or has documents about vehicles that can close the gaps? Any hint on this is welcome! Please contact: fahrzeugregister@fiatspider.de or directly via the website at:
https://www.fiatspider.de/der-spider/registry
The current gaps in vehicle identification numbers between known numbers (presumably official gaps in bold):
124AS00019xx (0001885 – 0002061)
124AS00053xx (0005250 – 0005421)
124AS00086xx (0008553 – 0008752)
124AS00103xx (0010250 – 0010461)
124AS00106xx (0010576 – 0010716)
124AS00109xx (0010879 – 0011042)
124AS00112xx (0011179 – 0011322)
124AS00115xx (0011446 – 0011638)
124AS00119xx (0011824 – 0012154)
124AS00120xx
124AS00175xx (0017474 – 0017712)
124AS00176xx
124AS00179xx (0017890 – 0018075)
124AS00197xx (0019657 – 0019823)
124BS00220xx (0021955 – 0022181)
124BS00231xx (0023051 – 0023213)
124BS00252xx (0025187 – 0025391)
124BS00265xx (0026419 – 0026637)
124BS(1)00273xx (0027290 – 0027455)
124BS(1)00277xx (0027684 – 0027830)
124BS(1)00281xx (0028089 – 0028249)
124BS(1)00286xx (0028520 – 0028837)
124BS(1)00287xx
124BS(1)00306xx (003058x – 0030723)
124BS(1)00312xx (0031174 – 0031302)
124BS(1)00329xx (0032810 – 0033064)
124BS100422xx ( 0042177 – 0042332)
124BS100485xx (0048465 – 0048628)
124BS100492xx (0049170 – 0049421)
124BS100493xx
124BS100501xx (0050089 – 0050203)
124BS100507xx (0050617 – 0050835)
124BS100509xx (0050835 – 0051052)
124BS100514xx (0051382 – 0051555)
124BS100518xx (0051763 – 0051950)
124BS100563xx (0056263 – 0056422)
124BS100573xx (0057295 – 0057427)
124CS/CSA00639xx (0063886 – 0064085)
124CS/CSA00644xx (0064397 – 0064642)
124CS00655xx (0065470 – 0065629)
124CS/CS100658xx (0065795 - 0065906)
124CS00684xx (0068331 - 0068504)
124CS100745xx (0074481 – 0074613)
124CS100747xx (0074665 – 0074816)
124CS100755xx (0075498 – 0075640)
124CS100762xx (0076194 – 0076376)
124CS100797xx (0079641 – 0079804)
124CS100808xx (0080778 – 0080957)
124CS100825xx (0082423 – 0082640)
124CS100842xx (0084199 – 0084431)
124CS100843xx
124CS100848xx (0084796 – 0085053)
124CS100849xx
124CS100851xx (0085088 - 0085201)
124CS100893xx (0089284 – 0089412)
124CS100896xx (0089517 – 0089786)
124CS100917xx (0091685 – 0091805)
124CS100988xx (0098787 – 0098908)
124CS101247xx (0124697 – 0124805)
124CS101253xx (0125236 – 0125920)
124CS101254xx
124CS101421xx (0142014 - 0142504)
124CS101422xx
124CS201635xx (0163449 - 0164014)
124CS201636xx
ZFA 124CS001768xx (0176768 – 0176958)
ZFA 124CS081875xx (8187479 – 8188001)
ZFA 124CS081876xx
ZFA124CS081892xx (0189261 – 5000001)
ZFA124CS081893xx
ZFA124CS081894xx
ZFA124CS0050041xx (5004034 – 5500004)
ZFA124CS0050042xx
ZFR124DS0055037xx (5503627 – 5504001)
ZFR124DS0055038xx
ZFR124DS0055064xx (5506352 – 5510003)
ZFR124DS0055065xx
Last known identification number: ZFR124DS005511940
I am curious to see if we can close the gaps and thus confirm that FIAT has produced more than 200,000 vehicles.
Tensed greetings
