oil pooling on oil filter
grasshopper
Your car is a: 1976 Fiat Spider
Post by grasshopper »
Hi all. Does anyone else have engine oil pooling on top of oil filter ? I am using a Fram filter. Does this have anything to do with it ? It happens all the time. I am tightening the oil filter aprox 1 turn after contact with rubber gasket to housing. Am I over tightening perhaps ?
wetminkey
Re: oil pooling on oil filter
Post by wetminkey »
I smear the new filter's rubber gasket with fresh oil and tighten to as tight as I can by hand. No more.
I do this with all of the vehicles you see in my signature, plus some. None leak. And you can remove the filter, when necessary, easily.
Oil filters should not be tightened any more than what you can manage BY HAND. And they'll seal at that torque.
Learned that when I worked at Sears Automotive in 1975. Fort Collins, CO. One of the many things I learned,...
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
rridge
Your car is a: 1981 Turbo Spider
Post by rridge »
Any leak from the area above the oil filter will collect on the top of the oil filter. The seal on the oil pressure sender is good for about ten years.
grasshopper
Thanks for replies. I will hand tighten from now on !
tonym
Your car is a: 1979 spider 124
Post by tonym »
I had the same issue and I replaced the oil pressure sending unit and seal and problem solved.
I'll add my note of concurrence that, as stated above, oil collecting on top of the filter is often coming from either the oil pressure sending unit or the oil sending unit that turns on the "low oil pressure" light on the dash. Or both units if your car has them. Sometimes it's the metal gasket but often it is the actual sending unit body that is leaking. Also, oil pressure sending units also start getting more and more inaccurate as they age. When in doubt, replace.
grasshopper
Can the sealing washer be taken off of these oil sending units and be replaced ? I cant seem to take my washers off ?
If you could get the old washer off, you probably could replace it with a standard crush washer (if that's the right term), perhaps even a copper sealing washer. However, many times the leak from the sending unit is the unit itself, not the washer. I've even seen oil coming out from underneath of the male part of the spade lug electrical connector.
tima01864
Patron 2021
Patron 2021
Post by tima01864 »
Ever come to a conclusion?
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
Just ran into this on our new 71. Garage thought the filter seal was leaking and way way way overtightened the oil filter. Plus the fact that they just put in a new oil gauge sender in place of the idiot light ( so no light in the gauge) Had to replace the old LEAKING sender with a new correct light bulb sender and viola no more leak. Makes you scratch your head and go hmmmmmmm
