Stupid Question of the month
OK, so who can tell me what the Ex. Gas Sensor lamp on my car is for and under what circumstances it would come on and then what to do about it other than unscrew the bulb and ignore it.
- Your car is a: 1982 Fiat Spider 2000 Turbo
Re: Stupid Question of the month
Fuel injected cars have an exhaust gas sensor, otherwise known as an oxygen sensor. After 30,000 miles, the light will come on as a reminder to replace the O2 sensor. The purpose of the sensor is to measure the air/fuel ratio and provide feedback to the CPU, which fine tunes that ratio. If the sensor isn't working, you car should still run okay. But it won't be able to make peak power and/or fuel efficiency. A new O2 sensor only costs about $50 and is relatively easy to replace (it is the spark plug looking thing in you exhaust manifold.
You can also reset the light by pushing a button under the steering column. It is located in a black box. You simply remove the cover screw and push the button inside. The light will come on again in another 30,000 miles.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'62 Lancia Flaminia 2.5 3C Convertible
'68 Lancia Fulvia Sport Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
'12 Abarth 500
Perfect, thx.
The fiat I had a long time ago was a '78, so I was curious about the "new" lamp.
