Coolant Temperature Sensor
lugbutz
Your car is a: 1980 Fiat Spider
Post by lugbutz »
Hi.... so I am troubleshoot a "Cold Wont Start Issue" and have been using the follow Bosch FI diagnostic guide to help me work thru the process
https://drive.google.com/open?id=1QyoWu ... C9LiCPfEZP
I am at the section which tests the Coolant Temperature Sensor and says do an ohm reading on the Sensor at connection 13 on the ECU. The Manuals provides the following guide for testing the Sensor
OHMS Temp
7000-12000 -10C (14F)
2000-3000 . 20C (68F)
250-400 . 80C (176F)
With a ranging Ohm Meter set at 20K my reading is 3.90 which I believe translates to 3900 ohms and according to the document means the temperature is below 20C (68F) and above -20C (14F)
So My question is...according to the chart.... my sensor is ok? Is that correct?
rug
Your car is a: 1971 sport coupe
Re: Coolant Temperature Sensor
Post by rug »
What was your ambient temperature when you meassured the resistance? If it was around 15C your sensor should be fine.
/C
lugbutz
Post by lugbutz »
Ya it was around 15c....
Is there a formula I can use in the future?
lugbutz
Post by lugbutz »
