1980 Fiat Spider differential
sigkadetm
Your car is a: 1980 Fiat spider 2000
Post by sigkadetm »
The repair manual says the pinion rolling torque should be 14 to 17 inch pounds. I only have 7 inch pounds. Is it ok to tighten the pinion nut to obtain at least 14 inch pounds? I have the axle out of the car.
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: 1980 Fiat Spider differential
Post by RoyBatty »
You need to balance the rolling torque spec with the contact pattern.
If you have the pinion drawn in too far to achieve your rolling torque setting your contact pattern on the ring could be off.
