LED dash lights
LED dash lights
My 79 Pininfarina dash lights are pretty dim. Are LEDs an option? Thank you!!
- Your car is a: 1979 Spider
Re: LED dash lights
Yes, I put LED's in my '79's gauges....much improved!
Re: LED dash lights
Excellent, if you dont mind me asking....where did you buy them?? Thanks again.
Re: LED dash lights
I think i got them from superbrightleds.com
Re: LED dash lights
Re: LED dash lights
Big thank you Bonsai, looks like they are the 194 bulbs. Thanks again!!!
- nelsonj
Re: LED dash lights
Here is my write up with results and details - hope it helps.
Update: LED dash instruments lights installed.
Below is a writeup of my swap from standard lights to LED dash lights. My temp gauge light died, so I decided that, while I had the dash apart I would try LEDs. I only replaced the backlights (to try and get the dash brighter) and left standard lights for the oil idiot light, driving lights, high beams, and low on gas.
I got my lights from http://www.superbrightleds.com and they were a 5 element, about 80 lumen part (part number 194-CW5-CBT cool white). They were $3.95 per bulb - here is the receipt:
Note - most of my lights were 194 (I think) but my clock had a different light (per below). I checked my parts box and my old tach had lights similar to my clock. So, you should look at your gauges to see what type of lights they use before ordering parts. I had to do special (non-destructive) wiring for the clock and one light on my tach. The rest of the lights were plug and play. Note that the lights were not as snug as the originals, and one light fell into my speedo and I couldn't recover it - $4 down the drain.
Now for before and after pictures. I used the same camera, lens, aperture, shutter and ISO speed for all pictures. This should give you a true apples to apples comparison. For each gauge, the first picture is "before", the second picture is "after" - going from left to right on the dash. Note the car was not running at the time (my lights get brighter once the motor is 1000+ RPMs). The dash was "max bright" with the rheostat fully clockwise.
Gas Before:
Gas After:
Tach Before (only had one backlight):
Tach After (with two backlights):
Temp After (no before shot because the light was burned out when I started the project):
Speedo Before:
Speedo After:
Clock Before:
Clock After:
Full Dash Before:
Full Dash After:
Verdict and thoughts: My dash wasn't that bad to begin with. But it's noticeably brighter now (and can still be dimmed). The color is more blue and less yellow than original, but still looks good to my eyes - newer rather than vintage. The green light on the speedo and the set up of the tach make those two gauges look like they have different lights from the other three gauges.
Bottom line: I don't think this mod is for everyone. While the gaugues are brighter, I used 80 lumen bulbs ($4 each) but going with 100 lumen bulbs (at $6 each) would be even better. The fact that not all the gauges have the same "tone" may bother some and may make it look less than professional. I spent about $35 and had to do a bit of creative soldering and wiring - I plan on leaving the LEDs in because the dash is noticeably brighter.
Let me know if you have any questions.
Peace out.
Gas Before:
Gas After:
Speedo Before:
Speedo After:
Clock Before:
Clock After:
Full Dash Before:
Full Dash After:
Peace out.
Simi Valley, California
Spider 1800
Romans 10:9
Re: LED dash lights
Nelson,
Excellent write up!!! Very detailed and the pictures are great. Boy, now im not sure...lol. i do like the vintage look and not sold yet on having gauges look different light wise. I will have to mull this one over a bit. Thanks again!!!
Re: LED dash lights
The dash light dimmer reduces the brightness of the dash lights even when it its turned to full bright position. Some people simply eliminate the dimmer and are satisfied with the dash lights. This is done by connecting the 2 wire on the dimmer together.i do like the vintage look and not sold yet on having gauges look different light wise.
Other alternatives are switching the bulbs for brighter bulbs that are the same physical size.
The original bulb is a 158 draws 0.24 amps @ 14 volts
One option slightly brighter is a 194 draws 0.27 amp @14 volts
another option is the 168 bulb it draws 0.35 amp @14 volts.
Personally I do a lot of night driving and don't like the dash lights too bright. I replaced mine with the 168 bulbs and have them dimmed to about 70% of full bright.
- spidernut
Re: LED dash lights
The lights he posted would not stay solidly inserted in the gauges on my son's Spider. They kept popping out. I'm not sure why.
I found these worked better, stayed in and gave sufficient brightness to the gauges.
There are other styles that would place the LEDs closer to the actual gauge,
but these were about $3 for 10 of them on Ebay.
On my 79, I upgraded from the 3 watt incandescent bulb to a 5 watt 194 series incandescent from Auto Ricambi. It was a huge improvement and didn't have the bluish hue that LEDs put off. I am VERY pleased with them.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Re: LED dash lights
I like the look of your gauges now! Mine are very similar. Glad I could help. Happy motoring!
