Susp bushes
Baz
Your car is a: 1977 Fiat Spider
Susp bushes
Post by Baz »
Does anyone know if one can buy rubber front suspension bushes instead of nylon (to soften the ride) ??
Baz
DieselSpider
Re: Susp bushes
Post by DieselSpider »
Baz wrote:Does anyone know if one can buy rubber front suspension bushes instead of nylon (to soften the ride) ??
Baz
ASFAIK - The standard bushings are rubber and the brightly colored ones are polyurethane. Vicks, Alisons and Ricambi most of the time stock both.
Standard tire pressure should be at about 26 psi so I would start there and then verify if you have adjustable shocks set too stiff or possibly too stiff a set of shock absorbers for your preference.
