Rear axle oil seal replacement
maxdog
Patron 2019
Patron 2019
Your car is a: 1979 spyder 124
Post by maxdog »
Hi
I have an oil leak around the passenger side rear brake caliper . Hopefully it's a leaking caliper which is a simple fix . Sod's Law , the universal constant , probably dictates a failed axle oil seal . Or may be there's a blocked axle vent ,and pressure is building up in the axle, he said in jest
If it's the worst case , a failed seal
Is this a DIY fix or do I need professional help ??
Presumably I need a hub puller , are Fiat hubs easy to shift or are they like my old Jensen Interceptor hubs which have broken standard hub pullers, made strong men weep , and spawned a range of hefty fabricated iron ware ??
Is the seal a standard metric item or a FIAT special ? Any one have specification for the seal ?I'd like to buy it locally rather than import from the USA
Any advice or help would be appreciated.
Maxdog
131
Re: Rear axle oil seal replacement
Post by 131 »
Replacing the rear axle seal is easier than a full caliper rebuild. You do have to remove the caliper and mounting hardware. After removing the axle retaining bolts, I put a disc on the axle backwards, held on with wheel bolts engaged about 5 turns. I then abruptly pull the disc on the bolts like a slide hammer, very rarely does it not work.
Mick.
maxdog
Patron 2019
Patron 2019
Post by maxdog »
Thanks '
It's easier than I thought . Any idea of the dimensions or generic spec for the seal .
Maxdog
maxdog
Patron 2019
Patron 2019
Post by maxdog »
HI
Good news ! I discovered the rear axle breather , under a crusty looking lump on the axle casing . I removed it , cleared out the grot of ages ,replaced it , topped up the axle oil and went for a long run .
I'm happy to report that this has cured the oil leak at the rear wheel , one less job for the winter maintenance period .
Maxdog
