$2500 spark plug
Anything goes (within forum guidelines of course)
$2500 spark plug
So my brother-in-law starting experiencing a shudder in his Toyota Tacoma truck under heavy acceleration. Thinking it was auto trans related he took the truck into his local AAMCO shop. They convinced him it needed a trans overhaul to the tune of $2900. He negotiated them down to $2500 for the job. When he picked the truck up and went on a test drive with the mechanic, the symptoms were worse to the point the truck was undriveable. The mechanic told him it had a dtc of p303 which is a misfire code for cylinder #3. He brought the truck to me and I found #3 spark plug had failed and spark was arcing down the ceramic shell to ground. A new set of spark plugs cured the issue.
This is a text book example of an arcing problem.
Luckily, my bil had requested the old parts back from the trans overhaul. None of the parts that were replaced showed any wear or signs of damage. His next stop is the Bureau of Automotive Repair to open a dispute over repairs that weren't needed. But at this point it's a $2500 spark plug
Fiatlanta
Your car is a: 1979 Spider 124
Re: $2500 spark plug
Post by Fiatlanta »
Shady as hell. Hope he gets it sorted.
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
My wife went to AAMCO once, just to get the transmission checked. They told her it needed a new transmission. She called me, and I told her to leave. We kept that car four more years, and had no transmission problems.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
baltobernie
Post by baltobernie »
So Cal Mark wrote:... and spark was arcing down the ceramic shell to ground.
Like we say on this forum, "It's usually a grounding problem." :lol:
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
Un believable!!!
Kevin1
Post by Kevin1 »
Recently had a similar experience at the local Mazda dealer. Shuddering, stuttering, and shaking, diagnosed as a transmission, and an estimate of $2800 to fix it. Because that was worth more than the car I declined, drove the car home, and parked it. We had planned to replace this car, but had hoped we would get a couple of more years from it. So we went ahead with a replacement.
The Mazda sat for a couple of months, trying to decide what to do with it. On a hunch I went to VIP and had the OBD codes read. All that showed up was a random misfire, so I bought a set of plugs and six new coils. Problem fixed, for under $100.00. As this was now an "extra" car, we gave it to our daughter who is still driving it today.
The dealership had all kinds of excuses for the misdiagnosis, and insisted on showing me all the awards they have won for their service, as if that helped anything. I admit, some of them were pretty and looked just like like trophies. He kept trying to explain how these "computer controlled transmissions" will act up and shift wrong if a plug misfires (?!?!) making it hard to fix. I believe they just took my word as fact, since I described the problem felt as if the car was dropping in and out of gear when crusing along at part throttle. I doubt they drove it or even plugged it into their scanner.
I consider myself pretty knowledgeable when it comes to cars. It is frightening to think how many transmissions and other unnecessary repairs are sold to other people who only needed a tune-up. Live an learn.
baltobernie
Kevin1 wrote:The dealership had all kinds of excuses for the misdiagnosis ... he kept trying to explain how these "computer controlled transmissions" will act up and shift wrong if a plug misfires (?!?!) making it hard to fix.
This is believable. Ignition faults can masquerade as fuel or driveline faults. Wife's car threw fuel delivery codes at the dealer. Before commiting to extensive and expensive repairs, I searched the car forum and found several reports of coil-on-plug failures producing the same codes. Like you, I replaced all coils and plugs, and the problem disappeared. All parts, including the scanner, were less money than his (erroneous) estimate.
This is where the dealerships failed Mark, you, and I. There's no excuse for not performing an OBD scan. My cheap Harbor Freight one has diagnosed both our modern cars; the ones dealers and repair shops use have much more sophistication. The best tool won't work unless you use it.
TX82FIAT
Post by TX82FIAT »
So a good story about an honest kid. Yesterday I had to jump start my 2013 Acura TL after sitting for a few days while I was out of town. Car has 35K on odometer and I picked it up used with 19K OD. Thought the battery should last longer than that but figured it might need a new battery given the Texas heat. Tested battery and alternator determining it was indeed the battery, jumped it again and drove over to Autozone. The kid behind the counter said to take it to the dealership. I explained nicely that I really dislike going to the dealership for anything I can do myself. He said, "Mister, I can sell you a battery, but I think you have full or partial coverage from Acura on your car battery. It may not cost you a thing!"
I had never thought about a dead battery being covered under the warranty. Looked it up on an indeed it was covered or prorated after the first 3/36. Drove it to the dealer and they installed new $200 battery free of charge.
Drove back to the AutoZone today and slid the kid a $20 with a smile and a thank you.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
divace73
Post by divace73 »
TX82FIAT wrote:So a good story about an honest kid. Yesterday I had to jump start my 2013 Acura TL after sitting for a few days while I was out of town. Car has 35K on odometer and I picked it up used with 19K OD. Thought the battery should last longer than that but figured it might need a new battery given the Texas heat. Tested battery and alternator determining it was indeed the battery, jumped it again and drove over to Autozone. The kid behind the counter said to take it to the dealership. I explained nicely that I really dislike going to the dealership for anything I can do myself. He said, "Mister, I can sell you a battery, but I think you have full or partial coverage from Acura on your car battery. It may not cost you a thing!"
that nice to hear that you gave that kid a $20, wish there were more people out there like you..I like to say thank you, that sort of stuff makes my day and believe in humanity (and don't we need a lot of that lately)
Cheers David
see my >>You tube channel<<
Fiatlanta
Post by Fiatlanta »
Whatever happened?? Did they make it right?
1985spiderautomatic
Post by 1985spiderautomatic »
Wow.My first and last experience with a mechanic made me a mechanic.my 1967 Beaumont convertible is some where under carp rd. I drove it to Reds sitting on a milk crate at 100 miles an hour.
The car was a piece of shit.So i was told.Doing this today would mean jail time.We are talking 40 years ago.
How does this help?
You cant fix stupid!
That car and many more are buried.This is fiat forum? People keeping 30 year old Sophia lorens alive?
I got an update from my brother-in-law this weekend. He filed a complaint with the Bureau of Auto Repair. They investigated and cited the AAMCO shop for 3 violations and recommended a refund. The shop refused but offered to extend the warranty for an extra year, but no additional mileage. My BIL rejected that offer. They also told the investigator that they only did a "reseal", not a rebuild despite the repair order stating in 3 places that the trans was rebuilt. The investigator recommended Small Claims court and told my BIL that with a copy of the BAR report that he would win in a slam-dunk. Of course then he has to try to collect
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
That's the problem with small claims court. You win your case but YOU still have to collect. If the shop was cooperating in the first place you wouldn't need small claims court. but since the court doesn't order the offender to render restitution under any kind of penalty, most offenders just thumb their nose at the dog without teeth. I thought about it when I got the bum seat upholstery job, but MY time just wasn't worth all the time off, to go to court to get it resolved. Thank goodness we have the process, but it does leave something to be desired.
scrapironchef
Your car is a: 79 Spider
Post by scrapironchef »
All the more reason to buy you own OBD reader, you can get a very useful bluetooth one that will talk to you phone/tablet/pc and will make you a diagnostic genius. Under 5 bucks for the plug in and 5 bucks for the Torque app, it'll save you a lot of grief.
baltobernie
So Cal Mark wrote:... Of course then he has to try to collect
True, but he would be suing a brick-and-mortar shop, and a national franchisee to boot. If he could get an attorney to write an "or else" letter to AAMCO corporate, I'd say the chances are pretty good he would get relief.
