my spider is running fine but there is a slight problem
the car idles at about 1500 rpm´s and i can´t get it lower.
the adjustment screw is loose so the gas intake valve is shut
and it still idles at 1500 rpm
this evening i adjusted the timing and took it for a drive.
It still idles too high but the topspeed is 175 kmh on gps
at 80 kmh in fifth gear the rpm´s are about 4000
is this normal?
the car is running fine and handles well but is a bit thirsty
last time i drove 250 km on 32 liters of gas, but i have to say that sometimes my right foot is a bit heavy
one question left on the timing.There are three points on the marker by the crankshaft pulley top is 0 degrees
middle is 5 degrees and lower is 10 degrees .do i have to put it on 0,5,or 10 with the stroboscoop lamp
i tought it was at 10 degrees but then the rpm's are even higher
a lot of questions but hope someone can help
edit : forgot to mention that its a 1983 cs0 2000ie
