hd heater pipe
hd heater pipe
We have a new manufacturer producing heater pipes and they've sent us the first batch with the new hd flange. The flange is 1/4" thick to prevent warpage or leaks at the water pump mounting flange.
vandor
Re: hd heater pipe
Post by vandor »
Nice!!
spidernut
Re: hd heater pipe
Post by spidernut »
A much-needed improvement!
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
weengra
Your car is a: 82 Spider 2000 + 76 128 Sedan
Re: hd heater pipe
Post by weengra »
I'm not complaining, but I am curious as to why no one has these made to include the tab that attaches to the exhaust manifold? I love the HD flange and SS, but I don't understand the omission of the other piece. "Splain it to me! Thanks. b-
Bill Barker
Madison, Wisconsin
1982 Spider 2000
1976 128 Sedan
ClarkTheShark
Re: hd heater pipe
Post by ClarkTheShark »
I ended up welding a stainless tab to mine - The HD flange isnt even necessary with the addition of the tab.
The tab is probably omitted because it interferes with certain header pipes, etc.
KevAndAndi
Re: hd heater pipe
Post by KevAndAndi »
I think Mark recently mentioned that he was going to start selling the support tab.
Mark?
Kevin
1981 Spider 2000
Re: hd heater pipe
Post by RRoller123 »
An Adel clamp with the proper heat resistant cushion is needed, yes!
manoa matt
Re: hd heater pipe
Post by manoa matt »
Are longer mounting studs required?
Re: hd heater pipe
Probably not, as there appears to be enough room for another nut and washer on mine, but they were somewhat FrankenFiated I must say...
Re: hd heater pipe
the final steps in producing the strap are being done now. I should have them in about a week
aevansgatech
Re: hd heater pipe
Post by aevansgatech »
Mine arrives today!
Now that I've bypassed the heater core, this pipe will finish off this winter's cooling system overhaul
1979 Spider 2000 (gone)
sshukes
Re: hd heater pipe
Post by sshukes »
Just curious but shouldn't there "tee" for a tube that goes to the carborator?
sshukes
Re: hd heater pipe
Post by sshukes »
I'm a dummy, that's for an older car I have a76
Re: hd heater pipe
I have both versions in stock, with the nipple and without. If you modernize the carb with an electric choke, you don't need the small water line anymore
Re: hd heater pipe
Hi Mark: Did that water pipe support-bracket Adel-type Clamp idea ever go into production?
