Aluminum wheel center caps
- johnsje6
When I bought my '74 it had aluminum wheels that look kind of like wire wheels, pretty nice except the center caps are rusty. I want to get some caps and put these on my '79 after it gets painted, anyone know where to get some 2 3/4" (70mm) center caps? Do you need any measurement other than the diameter?
John J.
1979 Spider 2000
1979 Spider 2000
Re: Aluminum wheel center caps
I have several sizes of center caps for aluminum wheels
- johnsje6
Thanks, Mark, will take a look. Here is one of the wheels.........
John J.
1979 Spider 2000
1979 Spider 2000
- 124JOE
i use hydrofloric acid to clean up rust when detailing at work
I think hydrofloric acid is pretty dangerous if breathed in. Does anyone know how safe it is??
This safer method may help, phoshphoric, citric and carbonic acid all in one
http://www.youtube.com/watch?v=z7OdX42N ... ata_player
- 124JOE
its not so harsh. it needs to sit on for 30 to 45 seconds
I used muratic acid on my ALU rims once back in 1998
just 5 seconds or so and they were brilliant
rinse with plenty of water.joe
- Your car is a: 82 Spider 2000 + 76 128 Sedan
Hydrofluoric acid is very nasty and dangerous stuff. Do not use it!
http://www.sigmaaldrich.com/catalog/pro ... ®ion=US
Bill Barker
Madison, Wisconsin
1982 Spider 2000
1976 128 Sedan
Madison, Wisconsin
1982 Spider 2000
1976 128 Sedan
HF is used to etch glass. Extremely dangerous.
- 124JOE
well I guess im a dead man walking.
as I have had it on my hands
sprayed and a small mist passed my eyes
and inhailed some as well
it only burns if theres an open wound
ps we mix 50/50 with water
I serve as a consultant for a hazmat team. First off, HF is an OSHA "prior approval" chemical. This means my lab (with proper training and protective equipment) must get approval to even possess it. Our team uses fully encapsulated level A suits with SCBA to mitigate even small spills. Please don't underestimate the hazards associated with HF! Reagent grade conc. HF is ~60% and it will dissolve glass and of course skin, eyes and lung tissue as well. Perhaps Joe is using a diluted consumer version and diluting further in his shop to be relatively safe? In any case, clean wheels are not worth the risks (medical or legal) associated with conc. HF IMHO.
