I'm replacing the booster in my car and had a question about this plastic cover/cap/cup thing. Is it just for protection during shipping or must it stay in place when I fit the master cylinder?
I got the pushrod almost to spec but its basically bottomed out on the threads so no more adjustment.
Brake booster replacement
- V12StealthHunter
- Your car is a: 1971 Fiat 124 Spider
1971 Fiat 124 Sport Spider
- Your car is a: 1981 FIAT Spider 2000
Re: Brake booster replacement
http://www.international-auto.com/fiat- ... lation.cfm
It is the actuator adjustment and it is important to get right. Too far in and the pedal will travel to far with not enough effect. Too far out and the brakes will lock up as the pressure builds and cannot release.
Unfortunately, I know way too much about that damn nut.....
- V12StealthHunter
Do you know anything about my question about the plastic cover?
- azruss
As I recall, you need the plastic piece to keep the adjuster rod located in the center.
Sorry, no I don't.Do you know anything about my question about the plastic cover?
I quickly read your post and fired off an answer. Should have re-read that.
I have taken more than one booster off that I am confident are original and that plastic cup is in all of them. I looked in the Fiat Repair Manual and it is shown in the booster pictorial diagram as item 40, guide bushing. I have always installed them when replacing the booster. The opening of the cup faces out of the booster.
- V12StealthHunter
Any chance you could post that page from the manual?spider2081 wrote:I have taken more than one booster off that I am confident are original and that plastic cup is in all of them. I looked in the Fiat Repair Manual and it is shown in the booster pictorial diagram as item 40, guide bushing. I have always installed them when replacing the booster. The opening of the cup faces out of the booster.
When you say "opening" faces out, do you mean the inside of the cup? Or do you mean the hole in the centre as the opening?
- azruss
the back of the cup should fit against the seal, so when you look at it installed, you should see the inside of the cup.
Here are the pages:
Hope this helps
Hope this helps
- V12StealthHunter
Awesome thanks. Its the "guide bushing" according to that diagram.
