Spirited driving = sway bars?
Kingme2
Your car is a: 1980 124 Spider
Post by Kingme2 »
So, I have a huge list of front end parts I'm about to order, pondering sway bars...
The factory front sway bar is 3/4", I think. I see some of the vendors sell a 1"....
So, what is best value? Upgrade the front, or go rear... Or do I need to save up and do both
Due to recent budget cuts and the rising cost of electricity, gas, and oil, we have decided to turn off the light at the end of the tunnel. We apologize for any inconvenience.
1981 Fiat Spider, all black... "Corvino", italian for the Raven
SoFlaFiat
Re: Spirited driving = sway bars?
Post by SoFlaFiat »
I'm sure there are many opinions but I have gone with a 1" front and plan on seeing how that feels before adding a rear.
Kingme2
Post by Kingme2 »
Noticeable difference?
SoFlaFiat
Post by SoFlaFiat »
Wish I could say, but I haven't driven it yet... Someday soon!!
In any case, the rear is easy to install anytime you feel the need. Go with the 1" on the front no matter what, and add the rear if you like.
vandor
Post by vandor »
Since Spiders understeer a lot in stock form it is common to add a rear bar first, to reduce the understeer.
I really like my Spider with the 1" front and 5/8" rear bar, but I have friends that like to keep the stock front bar and add a rear bar.
azruss
Post by azruss »
i kept the stock front bar and added a rear bar from Mark Allison. Havent done extensive driving with it, but did test it out on some twisties with a very rough surface and also smooth curve. Everything under 50 mph. In that speed range the handling is so close to neutral.
FiatMac
Post by FiatMac »
I have a stock front with a 5/8 rear. This took care of the understeer. Ran on the track at VIR and handling was close to neutral.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
78 124 Spider on the rotisserie
76 124 Spider parts car or possible Lemons racer
83 parts car
narfire
Post by narfire »
I have the 1" front but no rear (yet). With the Koni yellows, handling is terrific, big improvement over stock and KYB's.
I have 205/15's as well that helps....
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
I had a Pinto that didn't come with any sway bars.
I put on both a front and rear, and it handled great.
Later on, I ran over a muffer some ancient car had deposited on the road,
and it broke the bracket for the front sway bar.
I took off the front, and enjoyed the oversteer for several years. Then I
took off the back (was having too much fun, plus I got older, and less adventurous).
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
redcars
Post by redcars »
I put on a 25mm front bar and that helped. I then add a 5/8 inch rear bar and like it better. The rear bar is needed to get rid of the under steer. I like no to a little over steer.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
msrichmond
Post by msrichmond »
I kept the front bar stock. I have progressive lowering springs from Spider-Point in Germany (I think these are available stateside now). Yellow Konis.
I have not seen anyone else suggest this, so I will, the tip came to me from Kelly Dicker of Wine Country Motors in Napa, CA.
Instead of a rear bar, you double the long trailing arms in back. Those arms are what give you rear roll stiffness as a single, and when doubled, the effect is amazing. And they are easy to install outside the brackets that carry the original ones. Yes, you need very long bolts to pair them.
I have 205/60-13 tires and what feels to me like neutral cornering and a smooth ride.
MikeR ('77 Spider)
Kingme2
Post by Kingme2 »
Went with front and back.it's only money.... Right???
Sb here in a few weeks with all the front end rebuild supplies.... The, in another 4-5 months Corvino can come out and get the work done.
Yep, sitting here with two boxes full of supplies, no car... :shock:
chrisg
Your car is a: 1971 FIAT
Post by chrisg »
On two cars I set up for spirited driving (and used thusly), I ran stiff springs (pick your flavor...there are more off-the-shelf flavors today than I had at the time), Konis (actually prefer the sport Konis on 'soft'), stock front bar & the typical (addco) rear bar (rubber bushings). I'm getting ready to do my '72 Coupe and and I'm rather excited about the easy choices on the market now for everything suspension-related (even loaded A-arms that with bushings that last more than 6 months!). I have a number of spare front & rear bars, so that part is easy (except finding the hardware), but I'm rather intrigued by the doubling the rear arm concept...anyone have photos?
Chris Granju
Knoxville, TN
81SPIDERMATT
Post by 81SPIDERMATT »
x2 on the double trailing arms .... pics ... build details
TStark
Your car is a: 1975 Spider
Post by TStark »
Seems to me the double trailing arms will torque some already sketchy metalurgy in a manner that was not intended.
