vacume advance
danaspider
Your car is a: 1979 Spider 2000 79 vw bus
vacume advance
Post by danaspider »
I have just replaced the vacume advance for the distributor for the 3rd time in the last 18 months. The last one lasted about 2 weeks. They fail by having a small tear in the diagrahm. (I took them apart to see where they failed)
Is anyone having this type of issue? Looking for ideas or a different version. Current one is "original" Marinela (sp)
Look forward to feedback
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
Re: vacume advance
do you have a heat shield on the exhaust?
danaspider
Re: vacume advance
Yep, I have the original heat shield in place. I did remove the piped outlet for the hot air to the air cleaner, ut welded a cover over the hole.
Luck Dana
79 Spider 2000
carb
danaspider
Re: vacume advance
Mark, do you have these in your parts supply?
Luck Dana
79 Spider 2000
carb
Re: vacume advance
I just sold my last unit from stock this afternoon. I should be getting an order early next week
