So I came home to this...
Like that is what I want to deal with right now. But, I have to sneak into a condo association to work on Monday and I can't do that in my diesel pig. This thing has to take me to work on Monday!!
So, out she is...
Tomorrow I'll sort out whether the spare goes in untouched and untried, or if I have the parts on hand to learn about replacing the front seal...
Re: So I came home to this...
That throws a monkey wrench into your plans. Before you put it back on make sure if those spring perches need any reinforcing.
I'll take a look at them Ari but the only work that happens to this car right now is stuff that keeps it barely running
Has anyone replaced the front seal with the pinion shaft in place? So maybe I don't have to completely disassemble the differential?
My understanding is count the turns on the pinion nut on removal and put it back in the same place, if I can't replace the collapsible spacer (crush washer?) sound right?
Thanks!!
Thanks!!
You don't have to disassemble the differential if the pinion seal is causing your leak. This may help:
http://www.youtube.com/watch?v=ha2Uhl9B ... ata_player
Thanks for the link Ari!
In the end, I couldn't find a seal, even though I thought I had one around. So, I stuck the spare rear end under there. Good news is, after a rip around the block, not a drop under the car. Bad news, on deceleration this rear end makes a faint whirring sound that was not present with the other. At least it will get me to work tomorrow and Csaba, I'll be in touch!
- btoran
- Your car is a: 1975 Fiat 124 Sport Spider
my kids always go to the bathroom before they go to sleep. otherwise, it looks like that in the morning. might want to suggest the car does the same.
1975 Fiat 124 Spider
I'll talk to her tonight!!
Might have to get some big ass diapers, she did it again last night!
Moral support...that is a gorgeous color! Make her happy. Good luck.
Thanks! It's an early 90's Saab color called Berel Green. I painted it in 1993 when I was just learning. Needs a redo at this point.JCelesia wrote:Moral support...that is a gorgeous color! Make her happy. Good luck.
The work schedule has been insane, 84 hours last week... But I did get a new seal and hopefully can swap the old rear end with a new seal back in over the weekend.
- Your car is a: 1975 Spider
what kind of fluid is in your rear diff, that looks very thin
son has 78 spider
son has 78 spider
90 gear oil, Mobil...
Sorry, I didn't mention that it took a couple days while I was working 15 hours a day and not checking on the cars.
I miss my therapy and will work on both cars this weekend!!
