Rear Caliper Handbrake / Emergency Brake
Broadsword
Your car is a: 1970 124 Spider
Post by Broadsword »
I have dismantled both rear calipers from my 1970 Spider.
The arm that houses the ball to the end of the brake cable freely rotates on one, but not at all on the other.
Which is correct?
Many thanks.
redcars
Re: Rear Caliper Handbrake / Emergency Brake
Post by redcars »
They should rotate freely. Work on the stuck one and you should to be able to free it up.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
Broadsword
Excellent, thank you for that.
