Request for Camshaft Advice
- opus10583
- Your car is a: 1978 CS1
Hi,
One of Mark Allison's NOS 1800 shortblocks and Tobi's rebuilt '74 head are on their way to my mechanic.
I've already got a 32/36 DFEV feeding a single-plane intake manifold, and a 4-2 FIAT exhaust manifold funneled into a period Abarth exhaust system.
I'm working on getting a lightened flywheel and aluminum crank pulley.
I've neglected learning intake theory:
Whose and which cams do you recommend and then; Why?
(For now, it stops here.)
Thanks!
Mark
Thanks!
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
- Your car is a: 1975 Spider
Re: Request for Camshaft Advice
with the low compression of a stock 1800 bottom end and a stock head, i wouldnt go more than 40-80 / 80-40 cams. maybe even milder, the biggest reason, is as you increase the camshaft duration you are costing dynamic compression, and can easily over cam the engine and cost performance. fiats stock cams are a pretty good grind for oem.
son has 78 spider
son has 78 spider
if you were going with my cams, I'd suggest our 285v grind. IMHO, 40/80 is too agressive for your setup. I offer a similar grind to 40/80 but I consider it as a Stage II grind
Agreed with mark, i should read up on his grinds as i have installed a few sets
son has 78 spider
son has 78 spider
- opus10583
Hi,
Thank you both.
Where would 'Midwest Bayless' 234deg intake only' fit in this discussion?
Thanks again,
Mark
Thank you both.
Thanks again,
Mark
Build that 1800 all the way to the max
I'm going as far as a 2.0 will let me, well that's my plan anyways
That's if my builder permits me too
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
You are worrying meBEEK wrote:Agreed with mark, i should read up on his grinds as i have installed a few sets
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- opus10583
Hi,fiat218 wrote:Build that 1800 all the way to the max
No... The NOS short block from Mark saves me a bag and a half of money, but the CR precludes anything truly adventurous, which is just as well; the 124 has certain limits of its own, and I've another car that's perfect for full-on hooning.
With the carb and exhaust already in my car, and lightened flywheel and pulleys, it'll rev and sound great.
Only still dithering on the cam set, not sure it's worth the expense given what I've learned.
Mark
- opus10583
So Cal Mark wrote:oh, it's worth it
Hi Mark,
How's that?
How's your 285V differ from stock and what's that going to give me on the street?
Thanks again,
Mark
you'll notice a big difference in the midrange and top end. The engine will really pull from 3k rpm on up. The 285v has more duration and lift than the stock cams
Pulls nicely from 3000 rpm and up.
Opus, I suspect you have way more experience than myself with these cars, but After trying all kinds of set ups with my FI engine, I found the head is where the power is made with these cars. The cams I have, made the biggest improvement with the adjustable cam wheels and degree in the engine properly.opus10583 wrote:Only still dithering on the cam set, not sure it's worth the expense given what I've learned.
the 274 cams in your engine are much milder than the 285 grind, and by design are intended to work with a stock motor with oem fi
mark have you considered offering valves that are longer than oem for the reground cams. this way the valve shims will stay in the low end of the range? granted i have shims to 5.20 but they are heavy and most people dont have them. just a thought for you and your product line. i have tried lash caps (alfa shims) and actually broke one in the engine. trying to reduce valve train weight. years ago in a race motor.
cam boxes can also be milled, but this process is not easy either. most people who are adding performance cams are installing big valves. this way a longer stem valve could answer some problems
son has 78 spider
son has 78 spider
