Hi,
Related to my previous thread are there any special tricks (other plugging off the appropriate emmision connectors) do I need to do to make a single plane manifold work on my 1608? Will any 124 single plane work?. I believe this is the manifold off of a '74' 1800.
Any help would be appreciated.
Regards,
John D. Nicosia
Manifold 4334448
- Your car is a: 1971 Fiat Spider 1608cc
Re: Manifold 4334448
Hi,
If anyone has this part it mounts directly to my 1608. Now I am going to attempt to put on my DMSA carb.
Regards,
John D. Nicosia
Regards,
John D. Nicosia
- Your car is a: 1975 Spider
all twin cam manifolds will mount to the head. is it the best? i cannot answer by the casting number. Please send a picture
son has 78 spider
son has 78 spider
- Your car is a: 1972Spider
Hi JohnD,
I put a 34DMSA and single plane intake from a '74 and put it on my 1608 engine.
Works great! You are going to love it!
(I could never get my DHSA to work well.)
Here is a thread with a pic of the EGR removed.
http://fiatspider.com/f08/viewtopic.php?f=5&t=19104
The 16mm x 1.5 pitch is a fairly common oil drain plug.
Most auto parts stores have a rack of drain plugs and you can find one there.
The other ones were not so hard to find.
Good luck.
Dougieb
Good luck.
Dougieb
Thanks for the encouragement. I think I made my first mistake by putting the original DHSA carb on the manifold as now it is not holding idle. I have a 34 DMSA that I just rebuilt but I have a small problem. One of the brass tubes on base of the carb is broken. I researched that I could block off both of the tubes with no issue to the running of the car. Carb is rebuilt but I just need to block off both of the tubes on the base.
I will check out your thread!!!
Newbie John D. Nicosia
Thanks to all especially Dougieb for all the help getting my fiat up and running with a new 34 dmsa Carb!!!!!!
Re: Manifold - Follow Up
Hi,
I have been running my 71 spider (1608cc) for about 3 weeks now with the 34DMSA. I must say what a difference especially above 4K rpm. I am loving this carb. Again thanks to all who helped especially DougieB. The car runs great, idles better than it ever has and run up the red line with a noticeable increase in power. You can really feel it!
Next will be swapping out the head and cams during the winter.
Regards,
John D. Nicosia
1971 Fiat Spider
2012 Fiat 500C
Past
70 Fiat DIno Coupe
87 Fiat X19
91 Alfa Spider
94 Alfa 164 LS
91 Alfa 164 L
Regards,
John D. Nicosia
1971 Fiat Spider
2012 Fiat 500C
Past
70 Fiat DIno Coupe
87 Fiat X19
91 Alfa Spider
94 Alfa 164 LS
91 Alfa 164 L
