Carbs
fiat218
Carbs
Post by fiat218 »
If I took a photo of the carbs on the car, could some one identified the size if them, I have looked and looked for the numbers but I dont want to remove one to see if it is stamped on the base
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Re: Carbs
Post by dmwhiteoak »
Are these the ones that are gold plated? If they are Webers should they not be stamped on the base plate?
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
fiat218
Re: Carbs
Post by fiat218 »
dmwhiteoak wrote:Are these the ones that are gold plated? If they are Webers should they not be stamped on the base plate?
They re webers on the 79
If they are stamped,then it must be on the end where they sit together,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
srwilson
Your car is a: 1979 124 Fiat Spider 2000
Re: Carbs
Post by srwilson »
The stamping on my carb was on the side facing the cam tower. If you have a camera on your phone you can simply use your phone to snap a picture of the sides you can't see then just look at the pictures. Use the flash if you need to.
That is how I found mine.
-Steve
1979 Black Fiat Spider
2006 Black Chevy Silverado Crew Cab
fiat218
Re: Carbs
Post by fiat218 »
Ok, thnks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
